G. L. Perry
10-09-2003 09:38:07
I'm removing hubs on SC to paint/clean/grease. I couldn't get back bearing to slip off. I drove off one side with rubber hammer on the rear tin flange there. It popped off after a few hits, but took fairly hard blows to do it. Other side won't come off that way. Is there a way that I don't know to remove them easier? Also, on ones that came off, I was cleaning them up, and bearings, which look ok, just fell apart, rollers came out. I've never seen a bearing do this, unless plenty worn or races/tracks broken/worn down. These appear fine other than came apart. Am I looking at new bearings? or can these be put back in? I'm wondering if I damaged by driving off, yet both fell apart and one was off tractor when hitting the other one. Also, one outer race seems to be higher than the outer edge of hub on one side, and is lower than hub on other. They are both seated all the way in hubs that I can see. I'm wondering if someone has wrong bearings and just got some close to fit or what?? Also, no seal on one side at back, other had two felt seals jambed in it. A bad mechanic?? I guess that felt seal goes from hub to the outer tin flange?? It looks like it should pull over the hub in back and rides on inner surface of tin cover to me. There was a pinch in old ones and it was behind the hub when I took it out. Don't see how that would help seal anything there. Can I pack bearings slightly and just fill hubs with grease after on tractor? I've never had wheel bearings with a zerk to grease before. On seals, can those still be bought? Dealer or where? Bearings, I can get numbers of ones in it now maybe, but not sure they are correct ones. Anyone have numbers for bearings on any brand? Think these were Timkens, can't remember w/out looking now. So Simple, yet, So Hard!!!
