need case model 40 info
Rodger Beaton
10-08-2003 17:03:44
I would like to identify year, and engine type
and if manuals, parts are available?
Model 40 serial 5616327
I have jpegs I can send If you think you might be able to help?
thanks rodger
dctom
10-08-2003 18:58:15
 Re: need case model 40 info in reply to Rodger Beaton, 10-08-2003 17:03:44
roger, i think it went to canada, cant read dthe guys writeing well on build card but i am sure that is what it says are you in canada? dctom
dctom
10-08-2003 17:54:04
ROGER, 5616327 IS A DI BUILT MAY 9 1952 AND SHIPPED TO GENERAL SUPPLY CO JULY 7 1954 I CANT MAKE OUT WHERE IT WENT BUT WILL TRY MAYBE YU CAN FIGURE IT OUT---ISLINGTON PARADA---- CASE CHANGED INDUSTRIALS TO THE NUMBERS IN L953 30 FOR THE SI 40 FOR THE DI AND 50 FOR THE LAI IT IS A STANDARD D SERIES ENGINE DCTOM
Rodger Beaton
10-08-2003 23:25:14
 Re: Re: need case model 40 info in reply to dctom, 10-08-2003 17:54:04
wow, thanks for that great bit of news. Yes I found tractor in Killaloe, Ontario and have it at my summer place. It needs some fixing so I need to know a little about it. It has a monster bucket and powerloader with a huge box out the back with iron wheels in it. 4 cyl gas. What kind of engine would that be for parts?
dctom
10-09-2003 09:18:29
 Re: Re: Re: need case model 40 info in reply to Rodger Beaton, 10-08-2003 23:25:14
roger; the engine is the same as in any DC case , your tractor was fitted with a #40 poweer loader at the factory , dctom
Rodger Beaton
10-09-2003 12:47:53
 Re: Re: Re: Re: need case model 40 info in reply to dctom, 10-09-2003 09:18:29
is there a way of putting power steering on these old tractors? I have a neighbor with a International that he put some slave cylinders
on and has great power steering. but he had access to a tractor that was being dismantelled. I haven't started the DI yet, but the garageman said he had it running. I am not sure if there is power steering in there someplace? with this size bucket one would nver be able to turn it? Tnku Rodg
dctom
10-09-2003 16:24:54
 Re: Re: Re: Re: Re: need case model 40 info in reply to Rodger Beaton, 10-09-2003 12:47:53
yes; i beleive some guys have taken the p s from a case 500 and made it work on a d or di, you may be suprised it may steer rather easy when moveing dctom
