That brake pad thingy for the belt pulley
Les...fortunate
10-07-2003 19:05:10
I need one for the SC. Any idea if that's still available at a dealer or how hard they are to find?
Klyde
10-08-2003 18:15:22
 Re: That brake pad thingy for the belt pulley in reply to Les...fortunate, 10-07-2003 19:05:10
old part #O1412AB1
Les
10-08-2003 18:44:10
 Re: Re: That brake pad thingy for the belt pulley in reply to Klyde, 10-08-2003 18:15:22
Thanks, Klyde. I just emailed the dealership. Hope they either have one or can get one.
North M
10-08-2003 06:26:50
I had one made for my D in the city at a place that relined brakes. There is usually one business in every city that works on clutchs and brakes relining.
Baggsy-Wy
10-07-2003 21:22:21
I found one at our TSC store before it went out of business, and reopened with mostly yuppie horse feed. It was marked for a John Deere, but I bent the ears over tight and got it to fit on the arm of the SI. If nothing else, the JD dealer should have one for an A,B,H and you can retro fit. Was only about $5 if I remember right...
Les
10-08-2003 12:18:45
 Re: Re: That brake pad thingy for the belt pulley in reply to Baggsy-Wy, 10-07-2003 21:22:21
Too bad I don't live near no city, TSC, or John Deere dealership. Maybe I'll try the Case/IH dealership. It's not real close but I've had good luck getting parts from them in the past.
C. Amick
10-09-2003 14:24:04
 Re: Re: Re: That brake pad thingy for the belt pul in reply to Les, 10-08-2003 12:18:45
If it's just the lining you need, the brake places should be able to re-line it for you. They can bend that lining to match the curvature of the metal. If it's the whole piece you need, I think I know someone that may have one.
