installing electric RPM gauge on Case 570
Larry Hammer
10-07-2003 07:07:31
I want to install an electircal RPM gauge. When I go to the suppliers web site they ask about pulse rate of the generator. Of course the 570 has an alternator. What are they talking about? Larry
DKase
10-07-2003 14:34:04
 Re: installing electric RPM gauge on Case 570 in reply to Larry Hammer, 10-07-2003 07:07:31
I think the tach. drives off the alternater much like they do on the diesel pickups. I looked into putting one on my Ford diesel pickup till they started talking $500. This is not a mechanical drive off the alt. with a cable like some of the early diesel tractors had. It is electrical and I wish I knew how they work. Good Luck
dctom
10-07-2003 10:08:07
LARRY. HAVE NO IDEA WHAT THEY ARE TALKING ABOUT I HAVE ONE ON MY DC AND THE GENERATOR ISNT EVEN RUNNING AND IT WORKS FINE, JUST HOOKED UP TO THE DISTRIBUATOR, UNLESS YOUR 570 IS A DIESEL THAN MAYBE THAT IS WHERE THEY GET THE PULSE FROM, DCTOM
Frank
10-21-2003 00:27:32
 Re: Re: installing electric RPM gauge on Case 570 in reply to dctom, 10-07-2003 10:08:07
As the one reply noted that on a Diesel, there's no electrical pulse off the distributor so where do you hook the "green" wire? It needs a pulse like from an electrical fuel injector nozzle on a car, but with a mechanical injector? Might be a question to ask on Google.com for subject, "where to hook green wire for RPM gage?"
John Saeli
10-07-2003 10:36:13
Hey DCTOM!! A distributor on a DC?? We may have to take disciplinary action on this matter. I'll have to bring it to the Board.
dctom
10-07-2003 14:06:58
 Re: Re: Re: installing electric RPM gauge on Case in reply to John Saeli, 10-07-2003 10:36:13
YAH JOHN MAYBE YOU SHOULD, BUT I THINK THE DISTRIBUTOR DOSE A BETTER JOB PULLING WHEN HE LUGS WAY DOWN, I KNOW IF YOU GET INTO THE IMPULSE ON A MAG IT IS ALL OVER, MY PULLERS ARE THE ONLY ONES THAT HAVE THAT UNORTHODOX SET UP, THINK I CAN GET BY WITH 50 LICKS WITH A WET NOODLE? LOL DCTOM
Klyde
10-07-2003 18:22:23
 Re: Re: Re: Re: installing electric RPM gauge on C in reply to dctom, 10-07-2003 14:06:58
NO WAY are you lugging an engine down below impulse! (200rpm) And inless you are running an accel coil and dual point distributor its nowhere near as hot as a Case mag
John Saeli
10-07-2003 18:48:24
 Re: Re: Re: Re: Re: installing electric RPM gauge in reply to Klyde, 10-07-2003 18:22:23
Hey Klyde; I knew I could count on you. The council is in caucus as to the dicisiplinary action to be taken on DCTOM. I know his latest statement will add to the penality.
