Case 541 with Tripl range tranny - questions
RoyJoeBob
10-05-2003 09:45:11
Howdy folks! I am looking at a 1964 Case 541 with tripl range transmisssion. Are these good reliable trannies? I am not so familiar with them. I have a 730 case with dual range. They are asking $2500 with loader... seems like a fair price. The brakes go all the way to the bottom before stopping.. still stops good. Are there adjustments to brakes to give more pedal or how difficult to replace them? Any or all info on these tractors would be appreciated. Thanks Much!
RoyJoeBob
10-06-2003 11:35:36
 Re: Case 541 with Tripl range tranny - questions in reply to RoyJoeBob, 10-05-2003 09:45:11
Thanks for the input. Sounds like it I need to go make an offer on it. Love these dang tractors.....
dbock
10-05-2003 18:05:48
I have a Case 541 with the triple range and I haven't had any problems with the tranny yet. It does make a wine noise in low gear though. Also check to see how well the hand clutch works because I have tried to adjust mine but it still won't disengage all the way so that it can be shifted between gears; however this could be because my dad let it set for 20 years before I overhauled it. Overall, it is a really good little tractor.
John Saeli
10-05-2003 09:58:19
Hey RoyJoeBob; That triple range is a reliable tranny but can't be compared to the dual range 730. The 730 will take more pounding and abuse than the triple range. The triple range will give years of trouble free use. Before you buy it I'd check to see that it doesn't jump out of any of the ranges. The brakes are adjustable, the adjuster is on the rod down by the covers. It could need new discs by this time; It's no big job to change them. Hope this helps.
