Paint removal
Randy
05-16-1999 09:08:16
The sheey metal is in good shape. I am ready to remove and refinish. Should I sand Wire brush Or sand blast the sheet metal?
49 case sc
Martin
05-16-1999 19:18:01
 Re: Paint removal in reply to Randy, 05-16-1999 09:08:16
I don't suggest sand blasting the sheet metal, because it could cause a whole in the metal. A metal wire brush on a grinder or air tool is the best, but it may take a little more time.
David Davis
05-17-1999 09:17:19
 Re: Re: Paint removal in reply to Martin, 05-16-1999 19:18:01
If the sheet metal is that thin, nows the time to find out.Thats why I have a inlay tool and a mig welder.If you do not get rid of the rust it will grow and bubble under the new paint.Use fine sand when blasting and even on good metal keep moving.
Dave
David Davis
05-16-1999 11:50:14
The best and fastest way is sand blasting.You can rent a 120-150 CFM diesel compresser and blast pot from a rental store for $150 to $200 for the day. If you have every thing apart and ready it can be done in 4-5 hrs and takes around 1 ton of sand (took 1 ton for my badly rusted 43 S). Just make sure to get primer on it quick, nite air will start surface rust. Good Luck, Dave Davis
