VAC Project:Transmission/diff/brake rebuild
F-I-T
10-04-2003 17:52:19
third party image
Well, all the bearings finally arrived, but I'm short the front shaft seal, which will arrive on Tuesday.
Replaced all four bearings and races in the tranny, and the two differential bearings, races, and seals. Took my time to set the deifferential end play and then the pinion/ring gear mesh. All in all, it took me most of the afternoon and early evening.
JohnM
10-05-2003 07:03:24
 Re: VAC Project:Transmission/diff/brake rebuild in reply to F-I-T, 10-04-2003 17:52:19
Very gutsy move to paint FIRST and then rebuild! I am a novice and would have rebuilt everything and then thrown paint at her. How do you keep from dinging it up?
F-I-T
10-05-2003 07:48:25
 Re: Re: VAC Project:Transmission/diff/brake rebuil in reply to JohnM, 10-05-2003 07:03:24
John:
Making the transmission repairs after the paint was on wasn't my original plan. At first glance the bearings didin't seem all that bad, so I threw a coat of paint on it after I had it stripped to bare cast iron. Otherwise it would rust pretty fast down here in Florida.
Not to worry, it'll get two or possibly three more coats of acrylic enamel after the whole thing is assembled.
F-I-T
Finished Unit
10-04-2003 18:13:51
third party image
Well, does it look like there are over $400 in bearings, races and seals ? I was a bit surprised. If you ever decide to restore a tractor that has been let to sit out and collect loads of water, you can probably count on rusted and pitted bearings. After I finish replacing the front wheel bearings, the torque tube bearings and seal, and the rear axle bearings, races and seals, I think I'll have a little over $600 in those parts alone.
I sure hope she rolls smooth after all these parts!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
