Help removing axle from DC
RandyN
10-04-2003 15:03:14
Hello!
I have the nut loosened on the inside end of the axle as well as the axle cap off...but it won't budge. I'm wondering if the inner bearing cone is "stuck" to the axle.
Am I overlooking something?
Recommend any ways to "encourage" the axle to come out?
Perhaps I'll have to remove the other axle and drive this axle out?
Thanks ahead for any help,
RandyN
dctom
10-04-2003 15:19:07
 Re: Help removing axle from DC in reply to RandyN, 10-04-2003 15:03:14
get a good long pinch bar and pry between the two ends, that should encourage the axle to move out, i have already used a piece of flat stock between then and put a big wrench on nut and pipe wrench on axle and the threads will force the axle out shouldnt have to move far till it comes loose, hope this helps dctom
Randy N.
10-04-2003 17:53:35
 Re: Re: Help removing axle from DC in reply to dctom, 10-04-2003 15:19:07
Thanks, I will give it a try.
