wheel weights--install
Roger (Va.)
10-02-2003 17:39:49
I am currently seeking wheel weights for my Case 430 tractor, although I am not certain that the wheels are original for this tractor.
Is there any way to tell is these are the correct wheels?
If I do find weights, are there any methods for one man to install them with tools commonly found around a small farm? (have learned not to ask the wife to help with such things)
Thanks in advance
C. Amick
10-03-2003 13:25:32
 Re: wheel weights--install in reply to Roger (Va.), 10-02-2003 17:39:49
If you install the rear wheel weights by yourself, I suggest you use a come-along to suspend the weight from a tree limb and bring the tractor up to it. Whether you have the correct wheels or not, wheel weights are probably going to be hard to find for the 430. You may have to adapt weights from another tractor make.
