Case SC timing
Sheila Cole
10-02-2003 13:59:56
I removed the magneto cap to clean points and now dont know how to get back in time as I have moved the gear in cap. Need instructions or diaghram.
Thanks:Sheila
Klyde
10-02-2003 17:33:12
 Re: Case SC timing in reply to Sheila Cole, 10-02-2003 13:59:56
Is it a Case mag? If it is follow the other guys instructions. I'm just guessing here but it sounds like a F&M. (gear is in the cap- not in the cap on a Case mag) If it's a Fairbanks-Morse as i suspect, there are two marks on the fiber gear IN THE CAP, an A ( for anti-
clockwise)and a C (for clockwise) use the C mark. If they were on a little piece of white plastic and that is gone you will hafta find a new one or one with the marks on to remark it with. Steel gear has 1 tooth that is marked with a dot or a bevel or somtimes just a speck of red paint, and somtimes NOTHING. Hope this helps, Iread it 3 times and its clear as mud to me.
RoyG
10-02-2003 16:45:30
You will find two teath on small gear with dots on them and one tooth on fiber gear that is beveled, Beveled tooth goes between the two dots.
dctom
10-02-2003 16:45:13
thoes gears are marked, a red dot on one and two teeth on the other has little bevel on them red dot goes between the bevel teeth dctom
