DC PTO/Hydraulics?
Mike
10-01-2003 20:47:45
I recently acquired an old case DC I am not in the presence of the tractor of I would give you the serial numbers for some info on it. Anyway, the tractor has the PTO lever on the left front of the transmission under the dash, and there is another lever under the seat to the right. There is also a hydraulic hose in that area. My question is, does that lever under the seat control the hydraulics? there is only one hose that I see thoug, shouldn't there be another for a return line or something? Any help is appreciated. Also, as I dont have the serial number I do have a wealth of info on the tractor and I would like to find out what year it is so it would be of great help to me to help figure out the year thanks.
dctom
10-02-2003 07:02:12
 Re: DC PTO/Hydraulics? in reply to Mike, 10-01-2003 20:47:45
SEND SERIAL NUMBER AND I WILL SEND INFO FROM BUILD CARD, IT HAS TO BE 49-50-51.HYD UNIT ONLY RUNS WHEN PTO IS RUNNING DCTOM
MIke
10-02-2003 09:02:57
 Re: Re: DC PTO/Hydraulics? in reply to dctom, 10-02-2003 07:02:12
how would I be able to use those hydraulics? With a log splitter? wouldn't i need some sort of return?
dctom
10-02-2003 09:58:25
 Re: Re: Re: DC PTO/Hydraulics? in reply to MIke, 10-02-2003 09:02:57
Mike, there should be two outlets from the pump one on each side of it, lever will work for both directions of ram on splitter, maybe one is now hooked to filter can on side of pump houseing, un hook from there if it is and put plug in and use that hose dctom
