tractor show this weekend and my Case VC won't sta
John P. Martine
10-01-2003 18:53:58
Guys, help me out here, I have a 1941 Case VC. I had it running Sunday evening, a little on Monday and some on Tuesday. Tuesday afternoon it died and I can not get it started. There is no spark to the plugs. No spark from the coil to the distributor. I've changed the coil out twice. The distributor is a brand new replacement with an electronic device that replaces the points. I've got new wires and new spark plugs (set at 0.025). New battery too! I've pounded my head on the tractor for the last day and a half. Trying to get ready for the Texas Early Day Tractor and Engine Association Show October 3 & 4. I have 13+ volts on the battery. Just under a full 6 volts across the coil. My resistor is good. It warms up when the switch is turned on. What am I not doing. I know I'm missing something. I want to leave Thursday about noon to head out for the show in Temple Texas. If anyone can give me some advice, I NEED IT NOW! I may be able to check the discussion board Thursday night for any advise. --JPM
John P. Martine
10-02-2003 19:21:51
 Re: tractor show this weekend and my Case VC won't in reply to John P. Martine, 10-01-2003 18:53:58
Turns out that the "electronic points" were bad. I replaced them this morning and my tractor started immediately. Thanks for all your help!
C. Amick
10-02-2003 13:28:56
Does the device that replaced the points still have a condenser attached? Does it need one?
Lew
10-01-2003 20:35:49
I suspect the distributer is bad either mechanically (rotor does not turn)or electrically (electronics fried). With the cap off, spin the motor and see if the rotor rotates. It should. If not then you have a mechanical problem between the engine and the dist. (broken gear or pin) If it does then monitor the voltage at the input to the dist. while spinning the motor and see if the voltage varies as it should if the circuit is being closed then opened. If the resistor gets warm then current is flowing thru it but the dist. may not be opening the circuit as it should. Good luck
Casenut
10-02-2003 14:44:05
 Re: Re: tractor show this weekend and my Case VC w in reply to Lew, 10-01-2003 20:35:49
If it has an electronic ignition a resistor block should not be needed (probably low voltage to dist.
