930 CK Hydraulics getting hot
El Poppason
10-01-2003 15:26:28
Pulling a light disk(JD-BWA) with a CK 930 and the hydraulics got hot, or at least the control box on the rear above the pto was. The remote valves were centered, and there should have been no flow. I was just letting the plow trail, I wasn't raising it up and down repeatedly. BTW the lift and remote would still work.
What would cause this, and what is the remedy? And, where do you put in the fluid? Does it share fluid with the tranny, or are they separate?
Phil K.
10-05-2003 17:15:06
 Re: 930 CK Hydraulics getting hot in reply to El Poppason, 10-01-2003 15:26:28
The hydraulic-Transmission system operates on the same fluid. The system holds 17 gallons of HY-TRAN fluid. There should be a round cover on the left hand side of the hydraulic pump on the back side of the tractor.Pull up on the cover,there should be a dip stick attached to the cover,that is were you add the fluid.As far as the pump running hot,that may be normal. Phil
RoyG
10-01-2003 16:42:18
How HOt? The transmission which is the rsevore for the hyd system on a 930 will run as much as 100 degrees over ambiant temp. As for no flow - there is 15 gal of hyd flow through the remote valve at engine RPM as this is an open center hyd system. It should have no more pressure than it takes to flow the oil. My guess is that you don't have a problem as the remotes and lift will ork ok. hope this helps
Roy
Klyde
10-01-2003 17:28:18
 Re: Re: 930 CK Hydraulics getting hot in reply to RoyG, 10-01-2003 16:42:18
If the draft arm control is trying to lift all the time,(out of adjustment) that will cause the oil to get REAL HOT . just a thought
John Saeli
10-01-2003 17:38:30
 Re: Re: Re: 930 CK Hydraulics getting hot in reply to Klyde, 10-01-2003 17:28:18
Hey Klyde; You could have hit the nail on the head. I remember that the draft arm adj. was part of dealer prep. Listen up Roy: With the arms in fully raised position, you should be able to go back and still be able to lift the rockshaft some more. Hope this helps.
jimmie
03-24-2004 04:37:37
 Re: Re: Re: Re: 930 CK Hydraulics getting hot in reply to John Saeli, 10-01-2003 17:38:30
well the problem we are having with a 930 case is the tractor will not move but all hyd seen to work tractor just will not go forward anyone have any ideas thanks
