I also have question on a David Brown 990
School Teacher
09-30-2003 18:49:12
I found a 990 for sale and they say teh pump is bad. How hard & expensive is it to fix or replace. And like
John asked, where is the pump? Is it a gear or piston pump. WOuld it be possible to retofit another pump on the front and run a hose back to the lift unit? Also, this one has had the steering unit broken all the way around the mounting flange and recently welded back together. Will this hold and is it a common problem. The price seems great and it has great tires. I'm not familiar with this tractor but it seems hard to go wrong if it can be fixed.
Thanks
rod
10-01-2003 03:40:54
 Re: I also have question on a David Brown 990 in reply to School Teacher, 09-30-2003 18:49:12
pump is a gear type pump common problems are clogged filters this is at bottom of rear end housting it is a dish type plate filter is taken out by taking that plate off. the orings also can leak or blow out there is one in front of the pump not a big job to fix. adjustments are also a problem you need a manual to set it up. I have copies of the shop parts and ops manuals that I sell email me if you need any.
regards
rod
990 Implematic
