580c hoe problem
Russ
09-30-2003 16:31:31
The piston that makes the hoe go in/out is not working. It was working one day and the next day nothing. Other pistons work fine. No leaks that can be seen. Loosened the two hoses to the piston and no pressure. Checked the two valves in the control and replaced two missing O-rings. Still nothing. Any other suggestions????
JimKS
10-01-2003 19:07:23
 Re: 580c hoe problem in reply to Russ, 09-30-2003 16:31:31
That's odd- all other functions work normally? I think a 580c has a dipper priority valve... maybe something to do with that?
Russ
10-01-2003 20:09:10
 Re: Re: 580c hoe problem in reply to JimKS, 10-01-2003 19:07:23
I thought it was kind of strange too. I have the control assy out and will check it out. It's kind of strange, one day it worked fine, the next day it was dead.
Max
09-30-2003 19:27:49
Are you talking about the extendahoe, dipper, or bucket cylinder?
Russ
10-01-2003 12:39:43
 Re: Re: 580c hoe problem in reply to Max, 09-30-2003 19:27:49
I think it's called the extender.
Max
10-02-2003 06:35:56
 Re: Re: Re: 580c hoe problem in reply to Russ, 10-01-2003 12:39:43
The circuit relief for the extender valve section make have something under the relief valve causing the flow to bypass. To set the pressures correctly though you should use a high pressure hand pump for there is a chance that if the pressures are set to high, the cylinder rod will bend.
Russ
10-02-2003 19:32:48
 Re: Re: Re: Re: 580c hoe problem in reply to Max, 10-02-2003 06:35:56
Took the thing apart today. Found 4 o-rings missing. They were in the two center controls for the extension and the diper clyinders on the pop off valve with the small spring. Didn't find the o-rings anywhere. I'm not sure that this is the problem as the diper cly worked. Any ideas?????
Max
10-03-2003 21:01:13
 Re: Re: Re: Re: Re: 580c hoe problem in reply to Russ, 10-02-2003 19:32:48
After a while these orings start leaking by which creates heat, this gets the orings brittle and then any amount of backpressure surge will break the oring sending it through the hydraulic system. You might find the oring pieces in either the hydraulic filter or the suction screen.
Russ
10-04-2003 11:32:34
 Re: Re: Re: Re: Re: Re: 580c hoe problem in reply to Max, 10-03-2003 21:01:13
Would this be why the extender didn't work???
