David Brown 990 Implamatic Hydrolic Pump ????
John Suppa
09-30-2003 16:20:21
I have a 1962 990 implamatic with a weak hydrolic
pump. I have read most of the messages but none
actually tell me where the pump sits and how to get to it.Is it in the PTO bell housing or do I
have to split the tractor to get to it?
Can any one help?
rod
10-01-2003 03:45:38
 Re: David Brown 990 Implamatic Hydrolic Pump ???? in reply to John Suppa, 09-30-2003 16:20:21
You take off the pto housing it comes off as a unit and is pretty heavy once that is off you are at the pump four small bolts at bottom and two nuts on studs and pump is off there are orings inside it and one at bottom and on front, suggest you change filter also. I have and sell copies of parts, ops and shop manuals for the 990 let me know if you need any
regards
rod
