What size plow will a Case S pull?
chris
09-30-2003 14:39:24
I am wanting to find a plow for my Case S. I have a 3pt 2 bottom case plow, but my tractor doesn't have a 3pt. I need a plow that does not need hydrolics also. What model or size of plow do I need to look for? Does anybody have one forsale in southern IN. Thanks alot
dctom
09-30-2003 16:39:07
 Re: What size plow will a Case S pull? in reply to chris, 09-30-2003 14:39:24
Chris; 2x14 case centennial is just what you need, she will handle it like a toy
DCTOM
Chris
09-30-2003 18:03:28
 Re: Re: What size plow will a Case S pull? in reply to dctom, 09-30-2003 16:39:07
Thanks alot DCTOM! I will keep my eyes open for one.
dctom
09-30-2003 18:18:55
 Re: Re: Re: What size plow will a Case S pull? in reply to Chris, 09-30-2003 18:03:28
CHRIS; I HAVE A 2 16 MAY BE A LITTLE MUCH UNLESS YOU ARE IN LIGHT SOIL OR DONT GO TOO DEEP ALL PAINTED AND READY TO PLOW DCTOM
Chris
10-01-2003 07:27:28
 Re: Re: Re: Re: What size plow will a Case S pull? in reply to dctom, 09-30-2003 18:18:55
Where are you located. I'm in southern Idiana and we have mostly good old clay around the farm. We have a few acres that is sand ground but it's a long way from the shop. Everything we plow at shows is mostly clay as well. I don't plow very deep. Maybe 6 inches or so, just enough to make it look good. Everything that I plow deeper I plow with my 88 Oliver and my 3 bottom. Do you think a 2-16 will work in clay if I'm only going about 6" deep?
dctom
10-01-2003 10:26:12
 Re: Re: Re: Re: Re: What size plow will a Case S p in reply to Chris, 10-01-2003 07:27:28
CHRIS;, I CANT SAY FOR SURE, BUT MAYBE AND YOU WOULD HAVE TO WEIGHT HER DOWN SOME, I AM IN NORTHERN IND 20 MILES SOUTH OF SOUTH BEND, AM ASKING 200.00 FOR THE PLOW,IF YOU ARE INTRESTED FINE IF NOT NO PROBLEM. DCTOM
Chris
10-02-2003 15:24:00
 Re: Re: Re: Re: Re: Re: What size plow will a Case in reply to dctom, 10-01-2003 10:26:12
Thanks but I live in the southern most tip of Indiana and don't really have time to drive that far. I go to college thought the week and have to work on the weekends. I can only drive about 2 hours one way on sunday morning to get anything. I do appreciate your offer though. Maybe if I get a day off I can look You up again. Thanks alot for the help.
Will
10-01-2003 06:32:20
Tom, he might have traction problems with an S with anything larger than a 2x12. S has much smaller tires than an SC.
