Top Speed of VAI?
VAI Guy
09-29-2003 16:16:05
How fast does a VAI Case go? I know it is a heck of alot faster than a VAC.
Art
09-30-2003 03:42:26
 Re: Top Speed of VAI? in reply to VAI Guy, 09-29-2003 16:16:05
The industrials were geared very high in 4th gear as most of the vai"s were ment for road-side work (sicle bar mowers,and the like)After mowing all day, you would find yourself prety far from where you started, so the addition of a "road gear" made it a little quicker to get back to the barn...My VAI goes about 35 mph at idle in 4th gear....the other 3 gears seem to be a normal speed for a tractor....All I can say is hang on to your hat, an have fun...Also if you plan to use 4th alot, I would make sure I have realy good brakes, but thats just me.Good luck w/ your VAI
Mike
09-29-2003 16:44:32
I pull a Vai, at full power it scared the (#%^#) out of me!
Art
09-30-2003 03:44:20
 Re: Re: Top Speed of VAI? in reply to Mike, 09-29-2003 16:44:32
You pull in 4th gear?
mike
09-30-2003 04:28:56
 Re: Re: Re: Top Speed of VAI? in reply to Art, 09-30-2003 03:44:20
That would be great, but no.I pull in first gear,(4.8 mph).I put it 4th gear and pulled the throttle back, i ended up left of the driveway down in the middle of the field before i could get it stopped! Better than a roller coaster!!!!!
