Eagle Hitch Going Down- not !
Marty
09-29-2003 13:58:55
I have purchased a VAO and the eagle hitch raises with the lever beside the fender but does not lower. The lever only goes from about 10 o'clock to two o'clock. Is it possible it was removed and put on wrong ? I have seen others which operate between 2 o'clock and 5 o'clock. Does anyone know were the actual relief valve is to actuate the lowering of the lift ? Is it accessable from outside the casting around the cylinder ?
Thanks.
Marty
10-02-2003 09:16:05
 Re: Eagle Hitch Going Down- not ! in reply to Marty, 09-29-2003 13:58:55
Thanks to Joe and Mike, will be working on the tractor on the weekend !
Joe (Wa)
09-29-2003 21:42:04
Marty, lever movement 10-02 is normal.
The only valve accessable w/o removing the cam cover is the lift check valve under the plug on the bottom.
There are several reasons the draft arms will not drop under their own weight most common first:
1) leak-off tube is plugged with grease.
2) lift valve is not fully open (in neutral position) either because it is stuck or the return spring is broken.
3) the release valve to cam clearance is excessive and the lever is not opening the valve.
4) the rock shaft brgs are binding/hard grease.
5) the hydraulic return oil tube to the torque tube is restricted (crimped, flattened?) the return oil filter is not a factor, if plugged it will rupture.
First check the leak-off on the lower right side of the cylinder. When you disconnect the tube and work the hitch it is normal to get some oil and grease out of the fitting. It should clear up to a drop or two after 10 evolutions or so. Check the tubing clear back to the torque tube.
Other than that you will have to pull the right side lift arm and the cam cover to get @ the lift and release valves. With the lever in neutral the clearance between the cam adjusting screws and the stems of these valves is 0.010".
The release valve is fwd, the lift valve aft. The plug in between is the system relief valve. Joe
correction...Joe (Wa)
09-30-2003 14:48:36
 Re: Re: Eagle Hitch Going Down- not ! in reply to Joe (Wa), 09-29-2003 21:42:04
The last line of the above post should read:
The lift valve is fwd, the release valve is aft. The plug in between is the system relief valve.
Regret any heartburn. Joe
Mike
09-29-2003 16:54:41
Hey, remove the lever on the side, then remove the housing the lever moves in. Their should be three screws on the backing plate.behind all of that is a valve that the lever moves across. It's like and on-off switch. That end is filled with grease which can get hard and stick the valve.Just take it apart and see what is going on in there.
