VAC Project: Up in the air!
F-I-T
09-29-2003 08:20:05
third party image
Thanks to GeoMo for his thoughts on splitting stands. Here's the front end sitting proud. I didn't have any 2 1/2 tubing, but I had some thick wallewd 2", so I weled 4 cleats of 1/4" andle iron on at the entry end to make up the space.
Now I'll fab up something to bolt to the midsection, and I'll use my engine hoist on that. I'm trying to do everything as safely as possible.
Wish me luck!
Frank
GeoMo
09-30-2003 05:37:38
 Re: VAC Project: Up in the air! in reply to F-I-T, 09-29-2003 08:20:05
Looking good. Would you like to paint mine for me?
F-I-T
09-30-2003 17:15:00
 Re: Re: VAC Project: Up in the air! in reply to GeoMo, 09-30-2003 05:37:38
GeoMo:
I wish I hadn't put so much paint on only to have to gut the transmission today! After I got the bearings in the differential, I gave the pinion a spin and it absolutely rattled. After I took the transmission gears out, two of the bearing cages fell apart in my hands. Glad I didn't try and run it that way.
I've been teaching my self to paint for that last two years. Started with enamels, and now I've graduated to acrylic enamels and clearcoat. I found out it's not that tough provided you buy the right materials and have everything prepped, prepped, prepped! It's tough though as I am short on space, having started projects before I build my shop!
F-I-T...splittng is done!
09-29-2003 11:05:29
third party image
Well, it sure was a lot less trouble than I thought it would be!
Got the new differential bearings pressed on, and now I'll reassemble and set the endplay.
F-I-T
