611-B won't start - HELP!
Mike S
09-29-2003 08:07:50
I'm new to the tractor world. Just bought a 611-B (you can see it on the tractor picture link). It started for a couple of weeks or so just fine. The other day, I pulled the choke out and turned the engine over. it tried to start and then stalled. It hasn't started since. I smell gas when cranking the engine. I replaced the plugs. There is spark - though it doesn't look to be that strong of a spark. The exhaust cover is flapping - so there is compression to some level.
Fuel + Spark + Air = running engine - but it doesn't even give a note of starting.
What should I be looking for?
Jim M
09-29-2003 09:57:55
 Re: 611-B won't start - HELP! in reply to Mike S, 09-29-2003 08:07:50
Try manually holding the throttle butterfly closed while cranking. I've had the problem with a 511 and a 351 that they would stay open too much and not start
Mike
09-30-2003 06:25:19
 Re: Re: 611-B won't start - HELP! in reply to Jim M, 09-29-2003 09:57:55
Thanks. My son worked the choke in and out a few times - and the tractor started perfectly. I think the chock was stuck closed, but I haven't looked into it more.
