Case 590SL steering problem
sutto
09-29-2003 03:07:22
I have a Case 590SL series 2 backhoe which intermittently loses it's power steering. Steering is only ever lost while using the back bucket and it can be days or weeks between occurrences. Steering can eventually be regained by playing around with the rear control levers. The machine is fitted with ride control and is 1800 hrs old. Hydraulic oil and filters are new and a new steering priority valve has been fitted, all to no effect. Any ideas??
alrman
09-29-2003 05:49:59
 Re: Case 590SL steering problem in reply to sutto, 09-29-2003 03:07:22
sutto - could be the steering relief but I would keep persevering with the priority valve - it must be sticking - check to make sure it travels freely in it's bore. Make sure the orifice is clear - The best time to check it is when the problem next occurs - if time & circumstance will allow for it....cheers
