vai case gear ratios diff from vac
mike
09-28-2003 22:42:23
i have a vai with 11.2 24 it is high geared anyone know what the difference between it and a vac is is it in trans or finals thanks mike
Joe (Wa)
09-29-2003 13:52:30
 Re: vai case gear ratios diff from vac in reply to mike, 09-28-2003 22:42:23
I have a VAC-13 with 28" tires that clocks 35 mph full throttle in 4th. The only external diff is a low profile shift lever, stamped nrs seem to be normal VAC. Joe
wheat straw
09-29-2003 11:18:36
mike, I understand that it is the tranny. we have one and the tranny has a different 3 digit vt xxx # cast in the top of the tranny there by the gear shift. she gets up and moves huh? Have fun, Wheat Straw
Art
09-29-2003 11:15:17
I also have a VAI w/ the same tires sizes. I don't know what the gear ratio is, but I do know that it goes pretty fast in 4th gear. The first three gears seem normal enough. In 4th, at idle, it seems to go about 35 mph....Haven't needed to move the throttle off of idle when I'm in 4th.
