case mtd. sickle bar #10 mower question
Charles D. Zook
09-28-2003 13:00:48
Having prob. with the mtd. mower and the belt from pto that drives pitman, is slipping, and I do not see any adjustment, no idler pulley or split pulley adjustment to tighten up belt. Can any one provide info. on tightening belt? Thank you in advance. C.D. Zook
old school
09-28-2003 16:46:26
 Re: case mtd. sickle bar #10 mower question in reply to Charles D. Zook, 09-28-2003 13:00:48
the top pulley has 3 bolts on the flange.loosen the bolts and rotate . the shaft is offset in the housing.hope this helps
C.D. Zook
09-30-2003 05:00:53
 Re: Re: case mtd. sickle bar #10 mower question in reply to old school, 09-28-2003 16:46:26
Old school, Thanks for your help. Followed your advice, and it corrected the loose belt prob. Have a good day! C.D. Zook
