'41 SC pto not working
Josh
09-28-2003 08:52:58
I have a 1941 SC that i recently purchased. I am unsure of how to engage the PTO. I thought it was the small lever on the left up by the magneto ground switch on the dash, but the pto didn't turn with the lever front or back. Am i correct in assuming this is the pto lever, and something is broken? If something is broked, what should i look for first? Thanks a lot!
G. L. Perry
09-28-2003 10:23:00
 Re: '41 SC pto not working in reply to Josh, 09-28-2003 08:52:58
Was thinking Mine was on right side of steering column, down low, below dash. Just a straight, flat metal lever, no knob, with loose links to a rod going into case. Have to move it quite far to get in gear, farther than you might think at first. I have a question on the pto shaft. Mine had an extension on it, or so I thought. NOW, a fella looking at it says the orig is a smaller shaft and that was an adapter, not an extension. Zat so? I always thought there was the 6-spline for slow pto, and the 12-spline or whatever for the faster pto and that was it. Was there times when pto's were not all standard?? I'm not sure I will ever even use it, and extension was Ugly! But I better keep it around just in case, if it is an adapter.
dctom42
09-28-2003 10:27:42
 Re: Re: '41 SC pto not working in reply to G. L. Perry, 09-28-2003 10:23:00
Yes, pto's used to be smaller untill made sae, what you have is one that would make it larger for the sae standard pto shafts dctom
klyde
09-28-2003 09:07:45
Lever ahead to engage gears-- clutch must also be engaged to make the shaft turn. It's not constant running.
