VAC Starter Nut Removal
bob
09-28-2003 06:49:02
I have 49 VAC with a wobbly crankshaft pulley. I believe that there is a bushing that it rides on which has finally died after 54 years. What my problem is, how do I remove the nut for the hand starter on the end of the crank? Is it pressed on or threaded? If threaded, is it backwards thread and how would I keep the engine from turning over while turning the crank, besides removing the starter for flywheel acess?
Thanks.....Bob
Uggie
09-28-2003 16:49:14
 Re: VAC Starter Nut Removal in reply to bob, 09-28-2003 06:49:02
Bob,
F-I-T is correct with the collar. There is something very important that you need to know. If you heat the nut to remove there is a felt pad behind the pulley and there is a seal at the front of the crank. The heating could either cause damage or catch on fire. Also don't put a bearing puller on your belt pulley or you will likely be looking for a new one. Not real easy to find. It takes a lot of patience and tapping on the center close the cam. Then take like a pry bar off the front timing cover in several locations to pry evenly. Just a word of advise. Been there and done that. I would use a 3/4 impact if you had one. May have to take off front end to really get a good straight shot at the nut. Good luck!!!!
Jim
F-I-T
09-28-2003 07:05:27
Bob:
I've got my D-61 parts book for the VA tractors open in front of me, and I'm viewing the crankshaft diagram.
The pulley sets right on the crankshaft, and there is no bushing. The nut threads onto a male stub end of the crank. It is a right hand thread, or it would come loose when you cranked it. To loosen it, I would try blocking the wheels and then putting the tractor in gear (disable the ignition), and attempt to turn it off. It may take an impact wrench since it has been on there for a while, but maybe it will cooperate. The pulley is driven by the crankshaft by a woodruff key, and should slide off after the nut is removed. There is a felt and cork dust seal behind the pulley that you might have to replace.
I hope that the pulley is damaged, because the only other way for the pulley to wobble would be for the end of the crankshaft to be bent.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
bob
09-28-2003 09:15:33
 Re: Re: VAC Starter Nut Removal in reply to F-I-T, 09-28-2003 07:05:27
I tried putting the tractor in gear and blocking it, but I kept turning the engine/moving the tractor. My block wasn't big enough and I wanted to make sure the nut unscrewed and wasn't pressed on. Don't need to break anything else. My 3/4in. dr socket was too long to fit, so I have to get my 1/2dr socket from work tomorrow. Then use an impact gun. Using a wrench only turns the tractor over. There is a collar or washer behind the nut and in front of the pulley. I thought the collar was part of a bushing.
The wobble just started, so I cannot see the crank being bent.
Thanks...Bob
Slowpoke
09-29-2003 00:21:56
 Re: Re: Re: VAC Starter Nut Removal in reply to bob, 09-28-2003 09:15:33
I had occasion to crank my VAC the other day, and saw that the crank nut was hex and about 1 1/4". You might be able to use a long box wrench if the radiator is not removed. Put it in 4th and block the wheels, or chain it to a tree.
F-I-T
09-28-2003 10:00:57
Bob:
That piece right behind the nut is indeed called a collar. I hope you get it loose. If it wasn't so close to the timing cover and such, you coulr try some heat on the nut.
Maybe the hub has come loose on one side of the pulley?
Good luck!
Frank
