Case DC Manifold
case1950
09-26-2003 18:10:45
Does anybody know where to get a exhaust manifold for a 1952 Case DC-3? I was looking at the parts book and noticed they show ferrules under all exhaust and intake ports. I only had them under my intake ports. My other DC is the same way. Is that normal? and where can you find the ferrules?
Thanks,
Travis
Ted
09-27-2003 16:29:02
 Re: Case DC Manifold in reply to case1950, 09-26-2003 18:10:45
Don Livingston in Austin, MN sells new manifolds.
case1950
09-27-2003 19:09:07
 Re: Re: Case DC Manifold in reply to Ted, 09-27-2003 16:29:02
Does anybody have Don Livingston's email or phone number? How much does a manifold cost? Thanks for all the info.
Travis
Ted
09-28-2003 06:07:40
 Re: Re: Re: Case DC Manifold in reply to case1950, 09-27-2003 19:09:07
Don Livingston
18024 540th AVE
Austin Mn. 55912
ph 507 433 0073 mornings best
[email protected]
CTex
09-26-2003 18:41:50
Travis I almost forgot I have several D series exhaust manifolds. The DC is the same as the DC-4, D, DO, DI, just as long as you don't mix fuel manifolds. The gas manifold is a little different from the distillate one. I also have 2 propane manifolds that are different from each other. If you get a used one look closely under the air intake area for a weak area. I have found several burned into right there.
CTex
09-26-2003 18:34:59
Travis,
I prefer them at intake and exhaust. You can make them quite easy with a piece of exhaust pipe. Case also offers them with a complete head gasket kit.
Chris Hibbert
09-27-2003 06:26:41
 Re: Re: Case DC Manifold in reply to CTex, 09-26-2003 18:34:59
I never found them combined or offered with a complete gasket set but I got new gaskets and took them to the mufler store and had them expand a piece of pipe until it just barely fit through the holes of the gasket - took them home and had to cut them down slightly - just by cross cutting it and then they fit lie a glove.
Chris
Bob
09-27-2003 16:47:26
 Re: Re: Re: Case DC Manifold in reply to Chris Hibbert, 09-27-2003 06:26:41
I had exhaust ferrules made up for a C (same engine as D) using water pipe of near correct internal diameter, and machined down to fit manifold and head
