930 brakes
Tooly
09-25-2003 22:30:21
A friend of mine has a Case 930 that has a problem with the brakes,( it has none, so to speak) Since I havent seen the tractor personally and have not had much experience with Case, I was wondering if some of u Case guys could give me some ideas as to what we might run into here, and what it normaly takes to overhaul the brakes on these tractors, Thanks
MGM
09-26-2003 02:59:44
 Re: 930 brakes in reply to Tooly, 09-25-2003 22:30:21
I just got done doing mine, theres 6 total disks, what your probably going to see is lots of rust and or pitting in the sheaves, hone these spots out, I used kerosene and a nice small honeing stone. Therre are 3 balls that seperate the sheaves, makes sure they are shiny and the cups they sit in are not pitted. Keep in touch at my email if I can help you in anyway. Other than that its a tight fit with your head against the fender looking in to the brake area, I do have the manuals also.
Good Luck
Mike
