Need info about 1959 Case 300
Jim
05-13-1999 09:22:52
I'm looking to buy a tractor and just saw this ad: "1959 CASE 300 W/3 BUCKET, RUNS GREAT, $2,000 OBO". Can anyone tell me anything like horsepower, type of transmission, likelyhood of live PTO? Any information would be appreciated. Thanks
Jeff King
05-13-1999 18:29:33
 Re: Need info about 1959 Case 300 in reply to Jim, 05-13-1999 09:22:52
I have a '57 G310W with loader, fell for the same kind of line. Beware. Parts are very expensive. Check out the oil pressure when hot, if it is less than 15 psi, the engine will need work. A new oil pump is over $600.00. Change the oil and look at what you get out of the crankcase for metal or antifreeze signs. Also check the compression and condition of spark plugs. These engines are prone to cracking heads. I have $700.00 invested in a replacement cylinder head that I had rebuilt. As usual, check the hydraulics. Put a load in the bucket and attempt to leave it up in the air. If the cylinders leak down, is a sign they need to be rebuilt. Look at the power steering. Replacement parts are virtually non-obtainable and pieces from other rigs will need to be adapted if things are bad. Finally look at the rear tires. A 13.9 x 24 tire will easily run $300.00, so beware. A more reasonable price would be somewhere around $1200.00 if the obvious things check out.
Jeff
