SC valve settings
Sheila
09-25-2003 16:53:04
Could someone give me valve setting for SC.
Thank you
Mike Schotte
09-25-2003 17:14:08
 Re: SC valve settings in reply to Sheila, 09-25-2003 16:53:04
The I&T Shop Service Manual says both the inlet and exhaust valves on a "S" series Case tractor should be set to .010" cold.
However, the Case "S" series Operator's Manual says that "The clearance should be .010 inch when the valve is fully closed and the engine warm."
I don't know how much of a difference it makes either way on these old engines... but there are the two versions of the "correct" info that I have. (grin)
-Schotte
Slowpoke
09-29-2003 00:04:55
 Re: Re: SC valve settings in reply to Mike Schotte, 09-25-2003 17:14:08
I would think "cold" would be room (or factory)temperature of 72�, whereas "warm" would be comfortable for the hands or somewhat less than 125�. I measured a cup of coffee once, and found it too hot to drink at 125�, and nearly too hot to hold the cup not using the handle. Only about 40� difference there, but 110� difference if at operating temp of 180�. Much too hot to adjust valves without getting burned.
