CasVAC fuel lines
bob
09-24-2003 11:02:03
I am getting ready to replace the orginal water bowl with a different fuel filter/water seperator. My question is from reading in the archives, I saw about not using rubber fuel lines. Why? If I use regular auto fuel line in 5/16 or 3/8, why would I have problems? This is the same fuel line that cars use (designed for gas). Where would the problems arise from.
Thanks...Bob
C. Amick
09-25-2003 09:45:21
 Re: CasVAC fuel lines in reply to bob, 09-24-2003 11:02:03
Rubber fuel line is fine to use. Here's a suggestion. Leave the old sediment bowl on there. Go to NAPA auto parts or a lawn and garden center and buy a plastic fuel cut off valve. It's a ball valve. NAPA also carries clear plastic in-line fuel filters. Cut a secton out of your copper fuel line and install both items with the valve upstream.
Sheila Cole
09-26-2003 17:56:32
 Re: Re: CasVAC fuel lines in reply to C. Amick, 09-25-2003 09:45:21
Call me a dumb broad but totally restored a WD Allis Chalmers. Now working on Case SC need to know valve settings and carb adjustment settings.
C. Amick
09-29-2003 05:33:49
 Re: Re: Re: CasVAC fuel lines in reply to Sheila Cole, 09-26-2003 17:56:32
I think the valve settings are 0.010" cold for both intake and exhaust. The only carburetor setting that I have ever seen written is for the float. If that's what you need email me and I will look it up for you.
dctom
09-24-2003 11:24:47
UP TO YOU BUT NOT ORIGINAL I THINK MOST WERE THINKING OF JUST HOSE THAT DETERRIATES WITH GASOLINE JUST MY THOUGHTS DCTOM
bob
09-24-2003 17:35:08
 Re: Re: CasVAC fuel lines in reply to dctom, 09-24-2003 11:24:47
I also thought that the hose being talked about wasn't a gas fuel hose, but rather a generic rubber hose. As for being not original, I am looking more for better function (better filter)than that of looking correct. The tractor isn't a show tractor, and if I wanted to show it off someday, it is very easy to put back on a fuel bowl and a copper line. Thanks...Bob
Slowpoke
09-28-2003 23:32:37
 Re: Re: Re: CasVAC fuel lines in reply to bob, 09-24-2003 17:35:08
I changed mine to steel with inverted flare fittings. The copper line was all beat up and looked bad. Was copper with compression fittings OEM?
