580B Forward/Reverse
rb
09-23-2003 18:05:38
I have a Case 580B with a hydrostatic transmission. The tractor will move forward with no problems. Will not move in reverse. Pressure guage reads in the green forward and neutral, pressure dissapears when the leaver is shifted to reverse. Is this a problem in the shuttle, or would you think there is a valve or seal operating incorrectly somewhere? We are in the process of flushing out the fluids to see if that helps. Anymore ideas?
Appreciate it, -rb
DSB
06-28-2007 21:30:08
 Re: 580B Forward/Reverse in reply to rb, 09-23-2003 18:05:38
Clutch discs in the reverse pack are worn to the point they cannot seal as they should. The reverse normally go out just before the foward. Replace both sets while you're split.
Steve Schmittgens
09-25-2003 14:03:37
RB, If you have B with the hydrostat tranny & it's giving you this kind of trouble the problem is most likely the links that hold the hydrostatic pump & motor together. Feel free to call me @ (314)966-6692. I'd be happy to answer any questions, or help in any way.
Thanks, Steve
