Case S
Chris
09-23-2003 11:51:25
I am going to get a case s this weekend. Does anybody know of the ups and downs of these tractors? Anything generaly go wrong with them? Any other info? Thanks alot.
Baggsy-Wy
09-23-2003 16:34:36
 Re: Case S in reply to Chris, 09-23-2003 11:51:25
Just about everything on an S will switch out with an SC, except the front end. There's a wishbone piece of angle iron that comes from the front axle and ties in behind the oil pan. Make sure that the pivot ball and the two pieces of cast that hold it are intact. They are HARD to find. Not impossible, but not easy. I found a source that can have the balls made, but the casting is another story. If its wired up and cobbled together, cut the price in half and tell him why. Past that, start her up and put her thru the normal paces. Great old tractor, I hope it works out for you. Keep us posted...
Chris
09-24-2003 06:50:59
 Re: Re: Case S in reply to Baggsy-Wy, 09-23-2003 16:34:36
Thanks for the info and being an Oliver, John Deere, MM guy I'm sure you will here more out of me. This will be my first case tractor. Needed another bright color in the barn so I decided to get a case. They sure are good looking old tractors.
