Restoring grandpa's SC
Gary B
09-23-2003 10:31:08
Dad and I are working on restoring grandpa's SC. Dad recently re-acquired the tractor and it's gonna be an adventure. The carb, magneto, wiring and governor linkage were all gone.
I understand from the I&T manual that the SCs came with magnetos, but someone had apparently converted to a distributor setup. Was this common? We have a distributor that fits. Is there a "correct" place to put the coil?
We're not sure about the routing of the battery cables and starter switch wiring, or any of the wiring for that matter. Where do we find a picture or diagram? Clear pictures of both sides of the tractor and engine would be great. Are there any on line?
Finally, is "Flambeau Red" the correct paint color? I see from the "Caseworld" website that Napa 99L 3727, Dupont 016DH, Ditzler 71282, PPG 7128 are available. Any recommendations as to brand would be appreciated!
todd hamilton
09-23-2003 19:07:11
 Re: Restoring grandpa's SC in reply to Gary B, 09-23-2003 10:31:08
When I was a kid Dad had two old engines with mags. One was a 75 horse Johnson outboard and the other was his early SC Case. The SC that I have now has a distributor. Trust me - you are better off with a distributor. It is easier to service and not near as sensitive.
Mike Schotte
09-23-2003 15:30:14
Hi Gary,
Welcome to the SC fan club! (grin)
Hope I can help:
Case SC wiring diagram
NAPA Martin Senour and Crossfire paint codes for Flambeau Red
-Schotte
gerald kern
09-24-2003 16:11:36
 Re: Re: Restoring grandpa's SC in reply to Mike Schotte, 09-23-2003 15:30:14
Mike
I was interested in the paint of the Crossfire series at Napa. I called and gave them the # of the Martin Senour paint that you listed, #53A3727 and the gal there said she could not come up with that color (Flambeau Red) with those numbers. She thought a number might be missing. Is this for sure the number? Appreciate your help.
Gerald
C. Amick
09-23-2003 14:38:12
Yes, it is common to have an SC that has been converted to a distributor ignition. Case magneto parts got hard to find. I bought my coil mounting bracket from V a l u- b i l t Tractor Parts. Does the distrubutor set vertical (Delco) or horizontal (International Harvester)? Mike Schotte may have a wiring diagram scanned tha the can email you. Post a message for him.
