Need help with Decals!!
John Saeli
09-23-2003 09:37:54
I don't know how to apply the vinyl cut decals. Do I wet the metal surface? With what? I can't peel the colored surface off the tape. Do I soak them first? Any help appreciated. Thanks.
Gary B
09-23-2003 19:00:00
 Re: Need help with Decals!! in reply to John Saeli, 09-23-2003 09:37:54
If they are like the vinyl decals for my Mustang, they will be very slightly tacky on the backside, but not really sticky. Here is how it is done:
Position the decal and place tabs of masking tape along the top to hold it in position. Wet the painted surface with water to which a few drops of dishwashing liquid has been added. Carefully peel the backing off the decal while keeping it in position. Smooth the decal in place with a plastic squeegie from the center outward. After a few minutes the decal will begin to stick in place. Slowly peel the facing paper off the decal being very careful not to damage the decal. If the decal lifts, squeegie it back down and wait a few more minutes.
Keeping the surface wet during application makes it possible to reposition the decal before it sticks down. Small decals (6" across or less) don't really need the masking tape if you think you can position it correctly. Keep the surface wet until immediately before applying the decal.
Bubbles in the decal can be squeegied out. If decal is stuck down and won't allow the bubble to move, a small pinhole will let the air or water out and be nearly invisible. Time also takes care of most air bubbles and trapped water.
Gary
John Saeli
09-24-2003 04:25:16
 Re: Re: Need help with Decals!! in reply to Gary B, 09-23-2003 19:00:00
Hey Gary; Thanks much. I'll give it a try. The problem was that the facing paper would not peel off without starting to damage the decal.
C. Amick
09-23-2003 14:40:07
Are these John Deere decals?
John Saeli
09-23-2003 18:06:17
 Re: Re: Need help with Decals!! in reply to C. Amick, 09-23-2003 14:40:07
Shame on you C. Amick!! St. Peter has denied access for less.
Al
09-23-2003 14:00:46
Most new decals are self adhesive. So the most important thing is that the surface you are appling them to is clean and dry.
caseman-d
09-23-2003 11:41:24
John
Did you read the distructions :)
caseman-d
John Saeli
09-23-2003 18:04:29
 Re: Re: Need help with Decals!! in reply to caseman-d, 09-23-2003 11:41:24
Hey CASEMAN: They came with absolutely no instructions. I am stumped and need help!!
