LA Help - Identifying, Parts Paint Code
Brad From Austr
09-23-2003 04:41:35
Hi
I have 2 Case LA's one of which is in a Malcolm Moore Grader. Need help identifying both tractors, one has a number 621781 LA, the other has the plate missing, any ideas how to identify this one. Also looking for genuine or exact replica guages/instruments.
Having trouble getting the paint code for these tractors, CASE Australia tells me that "Power Tan" is the correct shade but this doesn't even sound right, also "Power Red" has been suggested as well. I've quoted "Desert Sunset" to the leading paint depot in South Australia and They can't find any reference to it.
HELP
Cheers In Advance
Brad Germein
Brad From Australia
09-24-2003 01:12:47
 Re: LA Help - Identifying, Parts Paint Code in reply to Brad From Australia, 09-23-2003 04:41:35
Hi again
Found following numbers on engine blocks.
5311573LA & LA4914213 & 621781LA
If anyone could help.
Cheers Brad
John H-WI
09-23-2003 05:33:16
LA's should be Flambeau Red. Not sure about the LA's but the S and D's have the serial number stamped on the block next to where it bolts to the transmission housing. You can try searching for the number there. Never seen a grader unit so can't tell you anything about them.
