Case 530 Hydraulic problem
Gary May
09-22-2003 17:58:05
I have a 530 Case with standard transmission that is leaking hydraulic fluid from the torque tube cavity into the transmission gear oil. I.E. the hydraulic fluid is going down and the gear lube level is going up. Nothing leaking externally. Is this a common problem and what is the most likely cause? Thanks in advance.
Terrance
09-22-2003 21:43:28
 Re: Case 530 Hydraulic problem in reply to Gary May, 09-22-2003 17:58:05
Does your 3pth stay up or does it leak down,if it leaks down you need to replace the seal in the lift cylinder for the hitch. If the hitch stays up then one of the seals between the transaxle and torque tube are leaking.One can be changed by removing the PTO unit and the shaft,it seals the pto shaft,the other is on the other end of that shaft and you need to split the tractor to replace it. Many people just use Tractor Hydraulic oil in both the torque tube and transaxle and never bother changing the seals. I know of a few that have been using Tractor Hydraulic oil in both the transaxle and Torque tube for about 20 years with no problems.
Hope this helps Terrance
Gary M
09-23-2003 17:24:36
 Re: Re: Case 530 Hydraulic problem in reply to Terrance, 09-22-2003 21:43:28
Thanks for the info. Terrance. The 3pt does not leak down so it must be in the pto seal. Using hydraulic fluid in both ends seems like a viable alternative. I've heard of other units that use it that way from factory.
