930 Clutch Replacement
case931
09-22-2003 11:17:43
Any advice or parts recommendations on replacing clutch disc in 1966 Comfort King diesel? Disc appears to be thin enough to let rivets just rub on flywheel bolts. Pressure plate looks almost new. Clutch disc has 6 pads - is this the correct configuration? I remember reading somewhere the early 930's had trouble with discs and the configuration was changed. I found a rebuilt disc at Worthington Ag - any other places someone can suggest?
Jim Handke
09-22-2003 14:16:23
 Re: 930 Clutch Replacement in reply to case931, 09-22-2003 11:17:43
Those button clutches had a history of wearing grooves in the flywheel. We found one so bad, it had to be refaced. It sounds like you caught yours in time. We've only done two 930 clutch jobs and they were both the regular clutches, material riveted all around the clutch. The button clutch was standard on the 1030.
