PTO racket
Tim W
05-12-1999 15:07:09
I tried pulling a 5' sidewinder rotary drag type mower with my 46 Case S. No problem with power, barely kicks the govrner, but on any more than a 15 degree turn its sounds like the guts are coming out of the tractor gear box.On the straight away it is quiet.This mower has a very long PTO shaft, what I call long coupled.Does any one make a mid-shaft knuckle joint and if so would this help? Any other ideas? Thanks
Tim W
05-13-1999 13:43:56
 Re: PTO racket in reply to Tim W, 05-12-1999 15:07:09
Don, Thanks for your reply. I checked and it is not binding or bottoming out.For the time being I am letting the draw bar swing about two holes left and right of center. For another thing ,the angle from the gear box on the mower to the PTO shaft is pretty steep, maybe 45 degrees.
Thanks again
Don
05-13-1999 06:05:14
Tim,
Are you sure that the two halfs of the mower PTO shaft are'nt bottoming out or binding up when you turn? This could cause the noise in your tractor PTO.
JHH
05-16-1999 02:11:15
 Re: Re: PTO racket in reply to Don, 05-13-1999 06:05:14
In order for a pto shaft to run smoothly the hitch pin must be exactly the same distance from each knuckle. Also the yoke of the knuckles on the center section of the shaft must both be turned the same way.
