41 SC how to check oil
towinwnc
09-21-2003 21:39:01
I have looked at this tractor and can't find a dip stick or a hole for it,do you check it some other way or has someone changed something.
cold canadian
09-22-2003 13:27:02
 Re: 41 SC how to check oil in reply to towinwnc, 09-21-2003 21:39:01
can you tell what type of oil to use in 1954 gas S tractor
Enjoy and Thanks
C. Amick
09-22-2003 07:21:39
I replaced the plugs on my Case SC oil pan with radiator drain cocks. The Farmalls have drain cocks on their oil pans for checking the oil level. I've never had a Farmall drain cock to loosen.
Mike Schotte
09-22-2003 04:54:15
Have to disagree with you slightly, G.L.
The oil level should be between the two level plugs, not full at the lowest plug.
"Although the oil level should be maintained to the level of the top plug, no difficulty will be experienced if the engine is operated with the level slightly below this top level. Under no circumstances should it be operated if the oil level is below the lower plug."
You are supposed to drain the oil down to the level of the lower plug and refill with fresh oil every 10 hours of operation if you are running on distillate, replace oil completely at 90 hours operation.
Every 30 hours if you are running on gasoline, replace oil completely every 120 hours (although I have never thought this necessary on gas.)
The capacitcy is 5 quarts if you are changing the oil only, SIX quarts if you have drained the wet clutch as well. (The wet clutch refills from the oiling system.)
Good point about a petcock on the oil pan hitting something and opening... that's why I have the type where it's a spring loaded plunger with a pull-ring on it.
There were 7,540 "SC" models built in 1941.
-Schotte
towinwnc
09-21-2003 22:01:06
Does anyone know how many 41 SC tractors were made.
G. L. Perry
09-21-2003 21:57:22
Yeah, this is odd to me too. My first Case is my SC. Look below on oil pan on right side of tractor (opposite the carb side) and you will see two pipe plugs in pan. Sometimes people have bought and installed petcock in at least one hole. One plug is higher than other. The oil filler is big cap above where dist or magneto is mounted. Tractor takes 5qts of oil when changed. The lower plug is the oil level. remove it and when oil comes out, it's full. OR, check for full oil there too. Upper plug is checked also first and if up to it, you need to remove lower and let some out to lower hole's level again. Manual states that the gas will dilute the oil, cause to overfill and must be drained down. Also, in winter water can collect in pan with temp changes and it can be some high then. Manual says to loosen drain plug and let out water till oil runs out and re-tighten. These both sound odd to me, kinda dumb really. I bought a couple of brass petcocks to put on mine, but I don't think I can get both in, as one will hit pan/block edge before It gets tight. Will use one in lower hole for sure. Then I can worry that something might come up and turn it and drain all the oil as I'm using the tractor!!
