Shift on the go --Case 430
Roger
09-21-2003 20:23:42
I have been told that it is Ok to shift from direct to high range, on the go, with my new (to me) Case 430 triple range. Have not tried to do it yet. How is this done? Any double clutching required? Do the gears, which I assume are not syncronized, crunch? Does this shifting hurt anything?
Thanks in advance
Roger
John Saeli
09-22-2003 04:39:15
 Re: Shift on the go --Case 430 in reply to Roger, 09-21-2003 20:23:42
Hey roger; This is sure to create some flack. I shift my triple range from low to direct to high on the go all the time. A dual range will shift the same also. Patience & common sense are a must. I double clutch. The foot throttle makes it real easy. Hope this helps
Roger (Va.)
09-24-2003 06:24:45
 Re: Re: Shift on the go --Case 430 in reply to John Saeli, 09-22-2003 04:39:15
Thanks for the info. Now I have to get up the nerve to try it.
