Nicholas: Nicholas: I have been using electrolysis cleaning for about two years now. I'm still using the same old 10-amp 6/12 volt charger that I started with. Only thing I had to do was to replace one clip on the red wire because I had it connected under water and of course it rusted. Now I connect through alligator jumper leads that are easier to replace. I use 18 ga stainless sheet for the electrodes as it lasts much longer than common cold rolled steel, but any old thing containing iron will work for sacrificial electrodes. I use Lye and washing soda (NOT BAKING SODA!). I like the washing soda because it is cheap, but I think the sodium hydroxide (Lye) does a faster job on removing paint and emulsifying grease and oil. I have never used a better/cheaper process! I have a large pressure sand blaster and an 8HP compressor, and I have not had to blast anything in over a year. I have the two front wheels from my VAC in the tank right now. In 24 hours or less, they will be oil, paint, and rust free, ready for primer and paint. I have some technical information on electrolysis posted on my website if you need more info. Frank-in-Tallahassee 70D // 855 // VAC
