Case 400
Scott KY
09-21-2003 09:40:18
Anyone know where I can get a fuel vacuume gauge for a 400 diesel? Iwould like to have an original.
Pat T
09-21-2003 15:55:47
 Re: Case 400 in reply to Scott KY, 09-21-2003 09:40:18
Talked to Don L about that quite a while ago, those are rare as gold nuggets even for him. I watched a NOS fuel pressure gauge for a 400 go for nearly $100 on E-Bay a while back, and those were quite a bit more common than the vacuum gauge. The only idea I can come up with would be to find a vacuum gauge that's close physically and send it to a guy known as the "Clock Doc" (info on the Unofficial Allis Forum) to be refaced with the Case script and coloring. Probably won't be a cheap date either, but unless someone starts to repro these things, that's about what we're left with, unless there's a garage full of them somewhere. If you do find a source, please post, I'd like one too.
Pat
John Saeli
09-21-2003 15:52:19
Hey Scott; I have NOS fuel guages.
Scott KY
09-21-2003 17:28:44
 Re: Re: Case 400 in reply to John Saeli, 09-21-2003 15:52:19
I'm not sure what you mean by fuel gauge. I am looking for the vacuume gauge that mounts under the steering column that detects restrictions in the first stage fuel filter.
SCHNEIDER
10-30-2003 14:38:32
 Re: Re: Re: Case 400 in reply to Scott KY, 09-21-2003 17:28:44
Does anyone know about the performance on a CASE 400 for a pulling tractor? Any answers related to this would be greatly appreciated!
John Saeli
09-22-2003 04:42:57
Hey Scott; I have fuel pressure guages. The vacuum guage measures air cleaner restriction, not fuel restriction. The dirtier the air cleaner, the more vacuum measured in the intake manifold. Hope this helps.
Milky2390
09-22-2003 21:01:05
 Re: Re: Re: Re: Case 400 in reply to John Saeli, 09-22-2003 04:42:57
On Case 400 & 600's there are two fuel pressure/vacuum gauges. The vacuum gauge measures the first stage filter restriction (beforetransfer pump) and the preasure gauge measures the second and third stage filter restriction.(after fuel transfer pump)
Milky2390
09-22-2003 21:03:56
 Re: Re: Re: Re: Re: Case 400 in reply to Milky2390, 09-22-2003 21:01:05
one other thought. Does anyone know what range the vacuum gauge measures?
Scott KY
09-22-2003 14:45:00
John,
I am no expert but my service manual says the vacuume gauge measures restriction in the first fuel filter. There is a small copper line that runs from the gauge to the fuel filter. This is on a big 400 not the smaller b model. I have a NOS fuel pressure gauge that goes to the second stage filter.
