What weight of oil would you put in the engine on
Nicholaus Sowde
09-20-2003 16:29:57
What weight of oil would you put in the engine on a Case Dc? What brand would you put in it? The oil filter has a element in it right? Would the case dealership have a new element? Do you all just put 10 weight oil in the air filter? I wiil try and get some pictures of it for you all. What happended to Casepower on here I haven't heard him post in a while. Thanks
Randy in MO
09-20-2003 18:18:21
 Re: What weight of oil would you put in the engine in reply to Nicholaus Sowder, 09-20-2003 16:29:57
Hi
The manual calls for 20 or 30 weight oil, but you can use 10W-30. As far as brands, Valvoline and Castrol do the best in research. Mobil 1 synthetic is an excellent oil, but for old engines it can flow too good and ends up leaking. If the engine is gunky and the prior owner(s)used NON DETERGENT oil, then you may wish to stick with that. Detergent oil will loosen up the gunk and may plug things up.
There is a filter element in the canister on the right hand side. I'm sure Case/IH may have the filter....you can also get them at auto parts stores or farm and home stores.
Enjoy,
RandyN in MO
