Case model C
tcr4
09-20-2003 15:30:23
I recently bought this tractor, and i'm disassembling it. I got to the rear wheels, and I can't seem to get them to move. they are the spoked style wheels, there was a nut and cotter pin holding them on that was removed. I then thought they should slide off. is there anything else holding them on? any help would be appreciated.
thenk you
tcr4
dctom
09-20-2003 16:39:52
 Re: Case model C in reply to tcr4, 09-20-2003 15:30:23
just a tapered shaft with a key, probley been on since tractor was new and rusted, ots of heat and a good puller or else if it will run leave nuts lose and drive it around till they get loose dctom
Dr Cy Kosis
09-20-2003 18:55:41
 Re: Re: Case model C in reply to dctom, 09-20-2003 16:39:52
DC,
Are the L wheels mounted the same way as the C?
I'll eventually need to remove mine and may go on and try breaking them loose ahead of time so it don't bite me later when time is a factor.
dctom
09-21-2003 16:37:13
 Re: Re: Re: Case model C in reply to Dr Cy Kosis, 09-20-2003 18:55:41
yes; as far as i know, i had a 29 l and it was a bear geting them off, justlots of heat and a good puller and big hammer lol dctom
