HELP!!! 995 steering collum leaking
Scott Braun
09-20-2003 08:02:55
I have a Case/ david Brown in good shape.I use it almost daily[work tractor].Recently it started leaking fluid (hydrolic power steering fluid?)from the top of the steering collum where the bearing is.My (I.T.)manual doesn't show a seal there.what is wrong??? thanks SGB
Elmer
09-20-2003 14:44:12
 Re: HELP!!! 995 steering collum leaking in reply to Scott Braun, 09-20-2003 08:02:55
The hand pump at the base of the column is leaking up the tube. You need to remove it and have it resealed.
