Case 430 red lights
Roger
09-19-2003 20:04:33
My new (to me) Case 430 has two red lights on the left side of the dash. What does each indicate?
Thanks
Glen of Ok.
09-20-2003 07:51:46
 Re: Case 430 red lights in reply to Roger, 09-19-2003 20:04:33
The two red lights are, left Gen, right Oil press. The 430 diesel is a very good tractor. I sold bunches of these in the 60's couldn't afford one for myself until I got out of the Case business. Bought one that I had sold new in 68 it is still going and is a good little tractor. If yours has been taked care of, and you take care of it it will be going when you are an old man.
Roger
09-20-2003 20:35:02
 Re: Re: Case 430 red lights in reply to Glen of Ok., 09-20-2003 07:51:46
Thanks for the info. I think I am going to like the 430. once I find the serial number and obtain a manual. I have other questions to post later.
Thanks again
LD5030
09-20-2003 06:29:39
I used to own a 430 diesel that had the two idiot lights you are talking about. One was for the generator and the other was oil pressure. Other than the tachometer you probably only have a water temperature gauge unless someone added an oil pressure gauge at a later time.
Hope this helps, jim
Roger
09-20-2003 20:06:04
 Re: Re: Case 430 red lights in reply to LD5030, 09-20-2003 06:29:39
Thanks for the info. I will be posting a few other questions later
Baggsy-Wy
09-19-2003 20:18:07
I don't see 'em on my 430...Tach above the steering wheel, temp gauge on the right, oil pressure on the left, choke, ignition switch, fuze, and light switch on the bottom across. Only red idiot light is below the tach, on the right of the steering column-generator charge light...jest to the left of the temp gauge and serial number plate. I think the panel is the same on the utility and GP tractor? What do you see?
Roger
09-19-2003 20:40:40
 Re: Re: Case 430 red lights in reply to Baggsy-Wy, 09-19-2003 20:18:07
I failed to mention that mine is a diesel. my dash is somewhat different. The two red lights are on the dash, just to the left of the steering column.
thanks
Mike Schotte
09-20-2003 06:37:11
 Re: Re: Re: Case 430 red lights in reply to Roger, 09-19-2003 20:40:40
If it's a diesel... isn't it possible that one light is an indicator for the glow plugs?
Roger
09-20-2003 20:22:22
 Re: Re: Re: Re: Case 430 red lights in reply to Mike Schotte, 09-20-2003 06:37:11
Thanks for your interest. Do all diesel tractors have glow indicators?
