830 CASE-O-MATIC
KIRK-TX
09-18-2003 11:40:25
I'LL TRY TO MAKE THIS BRIEF. I HAD TO REMOVE THE PLATE HOLDING THE FILTER AND OIL PUMP ON RIGHT SIDE OF TRACTOR. LOST ABOUT 2.5 GALLONS OF OIL. FORGOT TO ATTACH THE LINE GOING TO RADIATOR UNTILL AFTER ADDING OIL. ADDED OIL TO LEFT SIDE OF TRACTOR THRU DIPSTICK ABOVE CASE-O-MATIC VALVES. NO OIL RAN OUT OF UNATTACHED LINE. NOW C-O-M IS OVER FILLED. DID I REPLACE OIL INTO WRONG HOUSING? OR WILL OIL LEVEL EQUALIZE WHEN ENGINE IS STARTED? THANKS
turbo
09-18-2003 11:54:56
 Re: 830 CASE-O-MATIC in reply to KIRK-TX, 09-18-2003 11:40:25
Check Case-O-Matic oil level with engine at an idle.
That makes a difference.
