SC 3 11/16 Pistons
Rob in Virginia
09-18-2003 09:28:06
I saw the previous posts concerning using 3 11/16 "domed" pistons to boost horsepower in an SC. I have a 1950 SC with MW 3 11/16 pistons but they are flat top pistons. Will I see a similar HP increase with these pistons? I bought the tractor to restore and get into pulling but I read that SC's are not good pullers. The engine has two bad rod journals that will have to be turned. Everything else is good. I am questioning whether I should invest money in this tractor or sell it and get another model? Your opinions are welcome. Thanks.
mike
09-18-2003 09:43:18
 Re: SC 3 11/16 Pistons in reply to Rob in Virginia, 09-18-2003 09:28:06
What part of Va. are you located, you build that SC right you can work on some WC's and WD'S.I have a sc that is stuck with the M&W high dome pistons if you are interested.
Rob in Virginia
09-19-2003 09:09:50
 Re: Re: SC 3 11/16 Pistons in reply to mike, 09-18-2003 09:43:18
I'm near Roanoke, Va. The pistons I have are in good condition so I'll probably just stick with them. Thanks anyway.
C. Amick
09-19-2003 13:55:16
 Re: Re: Re: SC 3 11/16 Pistons in reply to Rob in Virginia, 09-19-2003 09:09:50
I have a set of 3-11/16 pistons that I need sleeves for. If you run across any spare sleeves, let me know. I'm in WV.
