Vac with loader ?????
Chris
09-17-2003 18:54:20
I am going to be looking into getting a tractor for use on my farm. I have 2 two cyl for the heavy work but i would like a small tractor with wide front to put a loader on. How much will the tractor with an aux hyd pump pick up
Thanks for your help.
BLR
09-17-2003 21:16:26
 Re: Vac with loader ????? in reply to Chris, 09-17-2003 18:54:20
I have a VA with a loader that operates from the standard engine driven hydraulic pump. The loader valve is an open center 4 spool valve plumbed into the high pressure line going from the pump to the eagle hitch. This allows me to operate the loader, a set of dual remotes at the back of the tractor, and an open valve for future applications. I have set the relief valve at 450 psi to help prevent breaking something. Even at that pressure I can still pick up a full bucket(which would best be catogorized as a manure bucket based on dimensions) of dirt with no problems. A couple of down sides are the tractor gets light in the back end with a full bucket, and the limited hydraulic reservior volume gets somewhat troublesome with single acting cylinders. My recommendations would be to get double acting cylinders all around on the loader, stick with a small bucket, and don't expect to tear out stumps or move the world. I originally bought the tractor to fix up and sell, but I like having the loader around for my light work so I'm going to keep it. Good luck
dave
05-02-2004 11:20:50
 Re: Re: Vac with loader ????? in reply to BLR, 09-17-2003 21:16:26
I would like to put a small loader on my vac 14 for light work and read your post,it sounds like just what I had in mind for the hydraulics.Would you be willing to send a picture of your set up?what make of loader have you installed?is it a trip bucket?Any help very appreciated
